crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓If the screen appears undamaged on the outside, but the screen is still unresponsive to charging or pressing the buttons, then the screen may need to be replaced. Use this guide to learn how to replace the screen.
First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
Continue to lift up on the band until the screen of the watch becomes loose from the band.
Continue to pull up on the wristband until it is completely off the watch.
Grab the watch once it is separated from the wristband.
Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
Gently pull the back panel away from the front panel.
Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
Remove the two 2.0 mm Torx Head screws with the T5 Torx screwdriver.
Use your fingers to gently pull the whole green motherboard out of the Front Casing.
Grab the screen attached to the green motherboard.
Using the pointed end of the black Spudger tool, gently pry the motherboard away from the screen.
Once you have the motherboard partially pried off, use your fingers to gently pop it out of the clear, plastic clips holding it in place.
Continue to pull the motherboard away from the screen to fully expose the white backing of the screen.
Once the white backing of the screen is exposed, carefully flip the two pieces, the motherboard and the screen, over while they are still connected.
Look for the small metal piece attached to the motherboard that is wrapped around the front of the screen.
Gently slide the screen under and back to free it from the metal piece.
Once free from the Front Casing and the motherboard, you are ready to replace the screen.
crwdns2947412:08crwdne2947412:0
Who sells the replacement screens? I can’t find them anywhere online. Do I need to contact TomTom directly?
Erin Espinoza - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Please help where can i buy the lcd
hjcouto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This article is useless unless you know where to buy the replacement screen!!!!
Kel Needham - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
this tutorial is without function because there is no sale of replacement screens. unfortunately
fielbicolor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
