Tofu65 Key Switch Replacement
  1. Tofu65 Key Switch Replacement, Key Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord.
  2. Tofu65 Key Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keycap by using a dedicated keycap remover or creating a hook-like tool with paperclips or using other tools.
    • Ensure that you pull it straight up without damaging the switch.
  3. Tofu65 Key Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tofu65 Key Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the keycap either by swabbing the inside and outside with a wet cotton swab or submerging the keycap in a small container with warm water for 30 minutes.
    • Hand/dish soap can be used as well but not necessary.
    • Dry the keycaps.
    • DO NOT leave the keycaps in sunlight or else they could warp.
  4. Tofu65 Key Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to remove the switch, locate the two switch housing pins near the top and bottom of the switch that hold it in the keyboard plate.
  5. Tofu65 Key Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The switch can be removed with a dedicated switch remover or two small flat head screwdrivers.
    • Pinch the dedicated switch remover tool on the two housing pins or push them in with the two screwdrivers.
  6. Tofu65 Key Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The switch should become loose.
    • Pull the switch straight up and out of the socket.
  7. Tofu65 Key Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before replacing the switch, ensure that the new switch does not have any bent pins.
    • If the pins are bent on the new switch, carefully bend them back so that they are pointing straight.
  8. Tofu65 Key Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tofu65 Key Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the pins with the sockets on the keyboard.
  9. Tofu65 Key Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly push straight down.
    • The switch should click into place and should fit tightly in the keyboard plate.
    • Ensure that it is level and flush.
  10. Tofu65 Key Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tofu65 Key Switch Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pop the respective keycaps back onto the switch by pushing straight down and firmly so that the cap fits all the way onto the switch.
    • Make sure that there is no residual moisture as any moisture can leak into the keyboard and cause water damage/break the entire keyboard.
Hanlin Chen
crwdns2935283:001/31/23crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-3, Morris Winter 2023 crwdns2935289:0UC Davis, Team 1-3, Morris Winter 2023crwdne2935289:0
UCD-MORRIS-W23S1G3
crwdns2942667:0crwdne2942667:0 284
