Toaster magnetic switch repair
  1. Toaster magnetic switch repair, Magnetic Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toaster magnetic switch repair, Magnetic Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove five screws, but the screws at the top left and right are special screws. I was able to loosen them with needle-nosed pliers and some fumbling and replaced them with Phillips screws
    • The second picture shows the very repair-unfriendly screw. Thank you Phillips!
  2. Toaster magnetic switch repair, Detach side panel and cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toaster magnetic switch repair, Detach side panel and cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The side wall can now be opened and removed together with the cover.
    • Do this carefully. I broke the cover
    • The control electronics are housed on the side wall and attached to the magnetic switch with a plug connection. The plug connection has to be loosened (in my case it almost came off by itself)
  3. Toaster magnetic switch repair, Remove magnetic switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toaster magnetic switch repair, Remove magnetic switch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The arrow points to the plug connection to the control electronics. When assembling, reattach accordingly
    • The magnetic switch is held in place by a clamp that is bolted to the bottom of the toaster (see second image).
    • I had toast crumbs between the magnets and the anchor, which prevented them from working properly. I removed/scraped off these crumbs.
    • Then reassemble in reverse order.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Ingmar
crwdns2935283:005/01/20crwdne2935283:0
136 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 3,023
