Tivax STB-T9 Daughterboard Replacement
  1. Tivax STB-T9 Daughterboard Replacement, Daughterboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax STB-T9 Daughterboard Replacement, Daughterboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the Tivax STB-T9 Digital TV Converter and unplug the device from power outlet.
  2. Tivax STB-T9 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #2 screwdriver, remove the screws from the sides of the box. (There are two screws, one on each side.)
    • You will be using the same Phillips #2 screwdriver (or bit P2 from the iFixit tool kit) for the all the screws removed in this guide.
  3. Tivax STB-T9 Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the screwdriver to remove the two screws found on the back of the device.
  4. Tivax STB-T9 Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the converter upside down.
    • Using the screwdriver, remove the two screws that connect the face plate to the main box.
  5. Tivax STB-T9 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax STB-T9 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, lift up on the back of the case and then slide it backwards to remove it from the device.
    • To ensure that the case fits when putting it back on, make sure the plastic surrounding the power cord is not in the way.
  6. Tivax STB-T9 Daughterboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax STB-T9 Daughterboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the cover removed, you will be able to access the internal components of the device.
    • Locate the white connector attached to the faceplate by black wires.
    • Place your forefinger and thumb on the sides of the connector. With little force, you should be able to pull the connector out.
    • Do not pull the connector out by yanking on the wires. This could rip them out of of the connector and cause damage. Only pull using the white plastic connector.
  7. Tivax STB-T9 Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tivax STB-T9 Daughterboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tivax STB-T9 Daughterboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the daughter board in the face plate.
    • Using the Phillips screwdriver, remove the four screws that connect the daughter board to the face plate.
    • Be sure to keep the daughter board screws separate from the face plate screws to avoid confusing them.
    • Once the screws are removed, gently lift up on the daughter board to remove it from the face plate.
To reassemble your device, please follow the steps in reverse order.
Olivia
crwdns2935283:002/11/16crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-4, Burgess Spring 2016 crwdns2935289:0Ohio State, Team 1-4, Burgess Spring 2016crwdne2935289:0
OSU-BURGESS-S16S1G4
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 461
