Tivax MiTraveler 10Q-8 Speaker Replacement
  1. Tivax MiTraveler 10Q-8 Speaker Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.9 mm screw from the charging port using a Phillips #000 screwdriver.
  3. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  4. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  5. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  6. Tivax MiTraveler 10Q-8 Speaker Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  7. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  8. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  9. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once both wires have been desoldered, remove the battery from the device.
  10. Tivax MiTraveler 10Q-8 Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the face of the device down, locate the speaker in the upper right corner.
    • Make sure the battery has been removed.
  11. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.9 mm screw holding the speaker in place using a Phillips #000 screwdriver.
  12. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
    • The wires will need to be soldered off the motherboard.
    • Locate where both wires are soldered to the motherboard.
    • Review How to Solder Here
  13. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work the iron where the red wire is soldered.
    • The wire will release from the motherboard.
  14. Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Speaker Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work the iron where the black wire is soldered.
    • The black wire will release from the motherboard.
    • After both wires have been soldered off, the speaker will release from the device.
Krista
crwdns2935283:003/11/15crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-3, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-3, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G3
crwdns2942667:0crwdne2942667:0 177
