Tivax MiTraveler 10Q-8 Rear Case Replacement
  1. Tivax MiTraveler 10Q-8 Rear Case Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Rear Case Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.9 mm screw from the charging port using a Phillips #000 screwdriver.
  3. Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  4. Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  5. Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Rear Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
To reassemble your device, simply slide the back plate back in to place and press down until you hear several clicks.
Maria
crwdns2935283:003/16/15crwdne2935283:0
210 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-3, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-3, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G3
crwdns2942667:0crwdne2942667:0 370
