Tivax MiTraveler 10Q-8 Motherboard Replacement
  1. Tivax MiTraveler 10Q-8 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.9 mm screw from the charging port using a Phillips #000 screwdriver.
  3. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  4. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  5. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  6. Tivax MiTraveler 10Q-8 Motherboard Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  7. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  8. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  9. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once both wires have been desoldered, remove the battery from the device.
  10. Tivax MiTraveler 10Q-8 Motherboard Replacement, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the face of the device down, locate the speaker in the upper right corner.
    • Make sure the battery has been removed.
  11. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.9 mm screw holding the speaker in place using a Phillips #000 screwdriver.
  12. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
    • The wires will need to be soldered off the motherboard.
    • Locate where both wires are soldered to the motherboard.
    • Review How to Solder Here
  13. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work the iron where the red wire is soldered.
    • The wire will release from the motherboard.
  14. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work the iron where the black wire is soldered.
    • The black wire will release from the motherboard.
    • After both wires have been soldered off, the speaker will release from the device.
  15. Tivax MiTraveler 10Q-8 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the black ribbon connector, flip the black portion of the connector upward.
    • Pull on the ribbon to remove from the connector.
    • Make sure battery has been removed.
  16. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the white ribbon connector from the motherboard.
  17. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the orange ribbon connector from the motherboard.
  18. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate a 2.88 mm Phillips head screw in the upper right hand corner of the mother board.
    • Use a #00 screw driver with the PH000 screw head to remove the screw.
  19. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate a 2.88 mm Phillips head screw on the lower left hand corner.
    • Use the #00 screw driver with the PH000 screw head to remove the screw.
  20. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate a strip of gold tape, which holds it to the device, on the bottom of the motherboard.
  21. Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the upper right hand corner of the device, a black wire connects to the device and runs to a strip of orange tape.
    • Remove the tape that holds the wire down.
    • Remove the motherboard from the device.
Conor Langenbahn
crwdns2935283:003/11/15crwdne2935283:0
228 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-3, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-3, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G3
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 417
