Tivax MiTraveler 10Q-8 Battery Replacement
  1. Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.9 mm screw from the charging port using a Phillips #000 screwdriver.
  3. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  4. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  5. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  6. Tivax MiTraveler 10Q-8 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  7. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  8. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  9. Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tivax MiTraveler 10Q-8 Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once both wires have been desoldered, remove the battery from the device.
Maria
crwdns2935283:003/16/15crwdne2935283:0
210 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-3, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-3, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G3
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 915
