First, you will have to refer to the back plate replacement guide. To replace the battery, be prepared to desolder two wires.
            With the device face down, slide the charging port cover off on the left side of device.
            Remove the 2.9 mm screw from the charging port using a Phillips #000 screwdriver.
            To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
            Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
            Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
            The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
            Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
            Review how to solder here.
            Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
            Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
            Once both wires have been desoldered, remove the battery from the device.
