Use this guide to replace the relief valve assembly in your Titan Elite 3000 High Pressure Airless Sprayer.
Turn off and unplug the sprayer.
Lay the sprayer down horizontally before continuing.
Use a pin punch and a hammer to drive the groove pin from right to left out of the valve handle.
Pull the valve handle straight off the cam base to remove it.
Remove the cam base.
Use a 17 mm wrench to loosen the relief valve assembly.
