Use this guide to replace the regulator assembly in your Titan Elite 3000 High Pressure Airless Sprayer.
Turn off and unplug the sprayer.
Lay the sprayer down horizontally before continuing.
Use a pick tool to scrape the red paint from the side of the pressure control knob.
Use a 2 mm Allen wrench to loosen the control knob.
Use a flathead screwdriver to pry and remove the clip securing the stop sleeve.
Remove the stop sleeve.
Remove the pressure spring.
Use an adjustable wrench to remove the regulator assembly.
