Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement
  1. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Unfasten the motor controller assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Unfasten the motor controller assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the four 12 mm-long screws securing the motor controller assembly.
  3. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Reposition the motor controller assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Reposition the motor controller assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Reposition the motor controller assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to remove the motor controller assembly completely, as it's connected to the body with cables.
    • Pull the motor controller assembly out and hold it to the side, exposing the cables.
  4. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Disconnect the spade connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Disconnect the spade connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of needle nose pliers, or your fingers, to disconnect the two spade connectors from to the on/off switch.
    • Disconnect the one spade connector on the circuit breaker.
    • Note the order of the cables and their connectors to help with reassembly.
  5. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the remaining spade connector from the on/off switch
    • Disconnect the jumper spade connector from the on/off switch and the circuit breaker.
    • The black jumper cable with the dark blue connectors isn't attached to the rest of the assembly.
  6. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the circuit breaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the circuit breaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to unscrew and remove the circuit breaker nut.
    • Remove the circuit breaker.
  7. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the on/off switch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the on/off switch: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the on/off switch: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to depress the locking tabs located on both the top and bottom of the on/off switch.
    • While depressing the tabs, push the on/off switch out through the cutout.
    • Remove the on/off switch.
  8. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Unfasten the contact switch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Unfasten the contact switch: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the two 17 mm-long screws securing the contact switch.
  9. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Reposition the contact switch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the contact switch away from the plunger and place it on the floor of the housing.
  10. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the retaining ring: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the retaining ring: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use snap ring pliers to remove the retaining ring from the top of the plunger.
    • During reassembly, install a new ring with the flat side facing down.
  11. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the control knob: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the control knob: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the control knob: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the pressure control knob.
    • Remove the pressure control knob.
  12. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the pressure adjustment spring: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the pressure adjustment spring: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pressure adjustment spring.
  13. Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the plunger: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Pressure Adjustment Assembly Replacement, Remove the plunger: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plunger.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
174 124 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 867crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 1,147
