Titan Airless Sprayer IMPACT 410 Capacitor Replacement
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
189,342 crwdns2915208:0crwdne2915208:0
crwdns2935297:0866crwdne2935297:0
Staff
crwdns2935297:023,276crwdne2935297:0
crwdns2942667:0crwdne2942667:0 586
