The Tineco FLOOR ONE S3 Breeze (model no. FW007600US) will sometimes have problems with the brush motor wearing out over time, and it may need to be replaced by removing the wheel cover plate and removing the existing motor. After a quick reassembly the machine is ready to operate. This replacement guide contains the following steps for the wheels replacement.
The brush motor allows the brush roller to operate and clean floors properly. Without the brush motor, the cleaner would not be able to complete it functions.
The first two steps of the wheel replacement guide is being used, but the third step is skipped for the brush motor replacement.
Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
Remove the first plastic cover.
Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
Remove the second plastic cover.
Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
Remove the wheels.
Remove the motor and the brush arm.
Remove three 10.56 mm screws from the gear with a Phillips #1 screwdriver.
Simply pull by the base of wires to remove them from the motor.
Remove the gear from the brush arm.
