Timex Ironman Triathlon Battery Replacement
  1. Timex Ironman Triathlon Battery Replacement, Remove Strap From: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Remove Strap From: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Remove Strap From: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use small flat tool such as a Flathead screwdriver to press the metal "spring bars" inward, one at a time, to release the wrist-band from the "Lugs."
    • Repeat first step on opposite side.
  2. Timex Ironman Triathlon Battery Replacement, Removing Backplate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Removing Backplate: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Removing Backplate: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screws the 4 screws using #000 Philips Bit.
    • Carefully remove back-plate, and lay it on its back.
  3. Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use JIS #000 Bit to unscrew the screw that secures the 2025 coin-cell battery underneath the white sticker.
    • Remove the screw from the eyelet, and place it to the side in a safe place.
  4. Timex Ironman Triathlon Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift contact-bracket up and peel dead battery off, for recycling.
    • Unlatch the empty contact-bracket by gently lifting the bracket up, off, and away from the plastic knuckle that is holding it onto the body of the watch.
    • Place contact-bracket face-up on a secure surface.
    • Place the positive(+) side of the new battery facing down on the contact-bracket.
  5. Timex Ironman Triathlon Battery Replacement, Secure New Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Secure New Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully replace contact-bracket by hanging the metal latch over the plastic knuckle.
    • Tighten screw.
    • Reset system settings by touching both gold pins with a conductive tool, such as the tip of a small Flathead screwdriver, or tweezers.
  6. Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace back-plate with logo facing same orientation as watch-face.
    • Replace and tighten screws from Step 2 with Bit #000, starting diagonally to create maximum water-resistance.
To reassemble your device, follow these steps in reverse, but remember to replace screws in a diagonal order to create a tight seal, and improve water-resistance.
Phoenixwa
crwdns2935283:003/16/22crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 528
