TiVo Series 2 TCD540080 Power Supply Replacement
  1. TiVo Series 2 TCD540080 Power Supply Replacement, Removal of TiVo Series 2 TCD540080 Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  5. TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
    • Do not pull on the power cables when disconnecting power connector.
  6. TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  7. TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four plastic standoffs.
    • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  8. TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Series 2 TCD540080 Power Supply Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power supply out of the unit.
    • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
Svyatoslav Markeyev
crwdns2935283:004/16/10crwdne2935283:0
135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 33-79, Johann Spring 2010 crwdns2935289:0Cal Poly, Team 33-79, Johann Spring 2010crwdne2935289:0
CPSU-JOHANN-S10S33G79
crwdns2942667:0crwdne2942667:0 5,279
