TiVo Bolt Hard Drive Replacement
  1. TiVo Bolt Hard Drive Replacement, Remove the Torx Screw on the Back: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This screw is a different length than all the other screws.
  2. TiVo Bolt Hard Drive Replacement, Remove Cable Card cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the clips to lift up the Cable card slot cover
  3. TiVo Bolt Hard Drive Replacement, Undo 2 Screws holding the case to the board/base: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not attempt to remove the housing yet. Still 3 more screws and plastic clips holding it in place
  4. TiVo Bolt Hard Drive Replacement, Remove the HDD Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Bolt Hard Drive Replacement, Remove the HDD Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This shows the placement of the clips so you know where to place your plastic pics.
    • Make sure to left this cover straight up when removing as you can see on the left side it has prongs that slide into the other part of the plastic housing.
    There’s a little bit missing from this step. The HDD cover is on the opposite side from the cablecard. It’s reasonably easy to unlatch the four clips along the outside, but difficult to unlatch the four clips along the inside edge that runs across the top of the case. It does not lift straight off. I got it off with a bit of muscle — lifting and a little twisting — the first time, but ended up breaking them all on a second go-around. It’s no matter, the four outside clips are plenty to hold it together.
    Jim Frost - crwdns2934203:0crwdne2934203:0
  5. TiVo Bolt Hard Drive Replacement, Remove 3 Remaining Screws Holding Case to Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Bolt Hard Drive Replacement, Remove 3 Remaining Screws Holding Case to Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Case is still clipped in so do not attempt to remove the case yet
  6. TiVo Bolt Hard Drive Replacement, Remove the Plastic Housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 TiVo Bolt Hard Drive Replacement, Remove the Plastic Housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Plastic Pic placement shows where the clips are.
    • I found it easy to use a 5th pic on the right to help separate the housing from the board
  7. TiVo Bolt Hard Drive Replacement, Remove Screw holding HDD Tray to the Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you undo this screw you can unplug the harddrive and left up the HDD to separate the HDD and tray from the Board
    • Then undo the screws holding the tray to the HDD. Put the Tray on you new HDD and screw it in.
  8. TiVo Bolt Hard Drive Replacement, Final Pictures of the board with the new HDD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TiVo Bolt Hard Drive Replacement, Final Pictures of the board with the new HDD: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TiVo Bolt Hard Drive Replacement, Final Pictures of the board with the new HDD: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Afterwards I decided to go ahead and add the plastic routing clips on, which are not shown in the picture.
crwdns2935229:014crwdne2935229:0
Jacob
crwdns2935283:009/22/18crwdne2935283:0
587 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
I’m using a bolt+. One thing I couldn’t figure out how to do was step 4 without breaking the clips for the HDD cover. Even though they snapped off, it’s generally not a big deal, and will actually make it easier the next time to take the thing apart. One thing I noticed about the design is the cooling is terrible. The fan is placed in an off-center area where it sucks air in and the pressure forces it to blow out the bottom. In addition, the HDD is sitting on top of a sealed area and has no airflow. For those with hard drive failures, heat is likely the culprit in this case…poor design. I’m not even gonna put the HDD cover back on. Instead I' have some 80mm usb powered fans I’m just gonna have blow straight into the side of the bolt across the HDD.
Gman - crwdns2934203:0crwdne2934203:0
Hello. Just wanted to send you this interesting article from backblaze about hard drive failure in relationship to heat. I am not disagreeing with you I think the heat distribution design does not work very well as I have also done the same thing and added a usb powered fan to the bottom of the TiVo. And since you seem to be interested in taking apart your TiVo. I’ll leave these articles here about using SSDs in DVRs. You may find it an interesting read. Link 1 and Link 2.
Jacob -
Any update to supported HDDs as the ones listed are no longer available?
Jerry D - crwdns2934203:0crwdne2934203:0
Very nice guide! Thank you, Jacob! I thought for sure I broke off those HDD cover tabs. They let loose with a mighty CRACK, but to my surprise, they were all intact. I replaced the existing bad HDD with a Toshiba 2TB (MQ03ABB200). Put everything back together, plugged it in and got the start up screen. It sat there for a while, formatting the HDD I assume, and then it went to the guided set up. It works perfectly now. So thankful for this guide!
Kieran Ecker - crwdns2934203:0crwdne2934203:0
Hi Kieran, how long did it take to format the HDD? Was there any indication as to how long to expect, like a timer or progress bar? Thanks for any advice you have.
zekeotsuka -
Hey Kieran, so there's no software needed to be installed on the HDD? The unit just boots up as normal and goes through the setup?
Steve Bell -
what do you do as far as formatting? Is there a built in firmware that can be reinstalled? I'm stuck on a Parental PIN problem and I can't access any settings, help?
Nic Christie - crwdns2934203:0crwdne2934203:0
HEY MY NAME IS JOHN REISSIGER,
I HAVE A TIVO PREMIERE SERIES 4 ARE THE ABOVE STEPS THE SAME TO REPLACE AND UPGRADE TO A NEW HARD DRIVE? MINE IS ON THE WELCOME SCREEN SINCE I MOVED AND IF THERE'S SOMETHING I'M MISSING PLEASE EMAIL ME AT THE FOLLOWING: jnreissiger@outlook.com THIS WAY I CAN RE-READ THE APROPREAITE INFO ALSO DOES THE FORMAT BUTTON PREFORM THE INITIAL FORMAT WHEN TURNED ON MY GUESS IS ABOUT 24 HOURS TO FULLY FORMAT AND REBOOT THE TIVO FROM THERE TO GET THE MAIN SCREEN? IS THIS CORRECT BASED ON WHAT I AM READING? EMAIL ME BACK THANKS,
JOHN
JOHN REISSIGER - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 116
crwdns2942667:0crwdne2942667:0 25,776
