Thrustmaster T3PM RJ12 main cable Replacement
  1. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
  2. Thrustmaster T3PM RJ12 main cable Replacement, Remove screws from the bottom: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove all screws at the bottom.
    • Keep track of each screw as to not loose it.
  3. Thrustmaster T3PM RJ12 main cable Replacement, Remove the top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover and put it aside
  4. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Tweezers to carefully remove the wires from the sensors
  5. Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tape and remove the cable
    • You can keep the original tape, add new tape or use some other method to stabilize the cable.
  6. Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully connect the wires of a new cable with the sensors
To reassemble your pedal set, follow these instructions in reverse order.
Formica Fusca
crwdns2935283:008/01/24crwdne2935283:0
2,587 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 825
