Replacing unresponsive R2 & L2 buttons on the throttle will help with game play.
Remove the five 15 mm J1 JIS head screws from the front of the throttle.
Using your hands, pull away the panel from the throttle.
Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
Pull the panel that is covering the R2 button away from the throttle.
Carefully push the R2 button from the outside of the panel.
Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
Carefully push the L2 button from the outside of the panel.
crwdns2917034:0crwdne2917034:0
Hello, m R2 button is broken. Do you know where i can print a new one ?
