Make sure you have a replacement ready! This will involve some drive formatting.
Remove the ten Phillips screws using a Philips 00 screwdriver
Pry up the case carefully using a spudger.
Lift off the cover, and you're done!
Carefully remove two Phillips screws with a Phillips 0 screwdriver
Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
Carefully remove the SSD enclosure.
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
