In this guide, you will learn how to open the ThinkPad X1 Carbon and replace the wireless card.
Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
Using the spudger pop the cover loose and remove.
Slide battery connector in the direction if the arrow to disconnect.
Remove screw holding the wireless card in place.
Carefully remove the antenna cables and slide out the card in the direction of the arrow.
