ThinkPad X1 Carbon SSD Replacement
crwdns2942287:0crwdne2942287:0You will learn how to open the ThinkPad X1 Carbon and replace the solid state drive. This guide only covers replacing the SSD. It does not cover loading the operating system back on the device.
crwdns2942215:0crwdne2942215:0
crwdns2942339:0crwdne2942339:0
crwdns2944105:0crwdne2944105:0
Use phillips #2 screwdriver to loosen seven cover screws.
Use spudger to pop open bottom cover, remove and set aside.
Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
Remove the SSD by sliding it out of the connector to the right.
I could be noted, that the M.2-connector has very strong spring, so at least my SSD pops up so hard it bounces the screw if not kept hold of. Also the insertion of SSD should be made in same angle as it comes out, not vertically sliding. The type of M.2 SSD is single-sided SATA, not NVMe.
crwdns2935229:012crwdne2935229:0
crwdns2947412:08crwdne2947412:0
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Can someone confirm the m.2 type on these units?
Is anyone aware (before I take mine apart) of whether or not a Gen 7 can accommodate a M.2 SSD fitted with a heatsink? Thanks.
X1 Carbon Gen 3 20BS here: It could be noted, that the M.2-connector has very strong spring, so at least my SSD pops up so hard it bounces the screw if not kept hold of. Also the insertion of SSD should be made in same angle as it comes out, not vertically sliding. The type of M.2 SSD is single-sided SATA (double-sided bends the connector too much, not enough space for proper fit), not NVMe.
Don’t forget to backup your data
Oliver - crwdns2934203:0crwdne2934203:0
