ThinkPad X1 Carbon Battery Replacement
  1. ThinkPad X1 Carbon Battery Replacement, Loosen Cover Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Battery Replacement, Remove Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spudger to pop loose cover and slide off.
  3. ThinkPad X1 Carbon Battery Replacement, Disconnect Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove five screws holding battery in place and remove battery.
    Mine had a fifth screw (inside that circle in the center of the battery)
    Vinod Kurup - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Mike
crwdns2935283:006/23/16crwdne2935283:0
1,906 crwdns2915208:0crwdne2915208:0
iReconstruction crwdns2935289:0iReconstructioncrwdne2935289:0
Business
crwdns2935297:017crwdne2935297:0
bonjour,
depuis que j’ai changé la batterie, elle ne charge plus… j’ai remis celle d’origine, idem…
Une idée?
merci d’avance.
Franck D'ALOIA - crwdns2934203:0crwdne2934203:0
Bonjour,
J’ai le même phénomène que celui décrit plus haut par Franck D’ALOIA. La batterie de remplacement indique 100% de charge mais ne tient que 10min tout au plus.
Une idée ??
Merci à vous
Lamine Bouras - crwdns2934203:0crwdne2934203:0
Minor correction to step #3 - the text says "remove 4 screws", but reality - and the photo - is that there are five screws.
Important: Note that the center one in the circular hole in the battery (under the trackpad) is a shorter length than the others.
davidhollway - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 254
crwdns2942667:0crwdne2942667:0 23,357
