ThinkPad Edge E31 RAM Replacement
    1. ThinkPad Edge E31 RAM  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • There are two two locks for the battery, one on the left and one on the right.
      • Slide the left lock to the left.
    2. ThinkPad Edge E31 RAM  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide and hold the right battery lock to the right.
      • While holding the right battery lock, slide the battery up to remove it from the laptop.
    1. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
      • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    1. ThinkPad Edge E31 RAM  Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The RAM slots are next to the hard drive to the right of the exposed laptop.
      • There are 2 flexible brackets holding each RAM chip in place is.
      • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
    2. ThinkPad Edge E31 RAM  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
    3. ThinkPad Edge E31 RAM  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
      • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
Riley
crwdns2935283:003/19/17crwdne2935283:0
613 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 crwdns2935289:0UMass Dartmouth, Team S6-G5, Isaacson Spring 2017crwdne2935289:0
UMASSD-ISAACSON-S17S6G5
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 727
