ThinkPad Edge E31 Hard Drive Replacement
  1. ThinkPad Edge E31 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Hard Drive Replacement, ThinkPad Edge E31 Underside Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
  4. ThinkPad Edge E31 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remember to ground yourself before handing internal components of a laptop.
    • The hard drive is on the bottom left side of the exposed laptop.
    • Remove the 3.5mm long M3 screw securing the hard drive to the laptop.
  5. ThinkPad Edge E31 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ThinkPad Edge E31 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the left edge of the hard drive there is a plastic tab. Pull up slightly on this tab.
    • Pull the tab to the left to remove the hard drive from the laptop.
  6. ThinkPad Edge E31 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the hard drive mounting bracket, locate the screws holding it on. There is one, 4mm long M2 screw on each of each on the long edges of the drive, and remove them. This will free the drive from the bracket. The bracket is needed to put the new drive back into the computer.
Riley
crwdns2935283:003/19/17crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 crwdns2935289:0UMass Dartmouth, Team S6-G5, Isaacson Spring 2017crwdne2935289:0
UMASSD-ISAACSON-S17S6G5
crwdns2942667:0crwdne2942667:0 472
