If the click on your buttons does not seem like it is performing optimally, there may be dirt around the switches. This guide will detail how to remove this debris to return the mouse to its optimal function.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the plastic cover and pack of weights.
Remove the two 1.0 mm foam covers with tweezers.
Peel away the plastic screw cover with tweezers.
Remove the four 1.0 mm screws with a Ph #1 screwdriver.
Gently remove the top of the mouse.
Use a Q-tip to clean around the switches.
