The Sharper Image Literati Tablet Keyboard Replacement
  1. The Sharper Image Literati Tablet Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
    For my model, 1637287 it was actually designed to slide out like a battery cover on a cell phone. The only place that might have reqired a little prying was on the white part of the case near the card reader/reset hole. There is a little plastic edge underneath, I pried that up then was able to wedge a spludger between the brown and white case line and slide up. Once I created a little space, I could push down and slide the white part up and off. To remove the brown case, there were 2 black screws revealed underneath that were holding it in place. Removed those, then I was able to do the same thing, push down and slide UP towards the top of tablet, the same direction as that the white case came off. Doing it the other way may brake some tabs, not sure how many models there were but this was the correct way to do it for mine. You wouldnt be able to fully pry off the brown part anyway because of how it is held in with 2 screws on mine.
    N. Watson - crwdns2934203:0crwdne2934203:0
  2. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
    A plastic card (I used an old AAA a card) worked better since it is more flexible. On my model 1637287 the battery was just held in place 2 pieces of short (about 3/4 in.) 3M like adhesive on either side. Not sure if it was age or the wide card I used but it was not too bad at all to get it to release, not like a Kindle battery or anything.
    This is NOT how you open them!!! I broke one of mine doing this. The white part SLIDES UP! DO not ply it open!!! Slide it up ( it needs a LITTLE ply around the silver part. ) It comes off then there are TWO SCREWS holding the brown part down. Once you remove the two screws ( they are under the white part ) then you can slide up the brown part too.
    Phynix Heart - crwdns2934203:0crwdne2934203:0
  5. The Sharper Image Literati Tablet Keyboard Replacement, SD Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver backing plate and the adhered SD port chip.
  13. The Sharper Image Literati Tablet Keyboard Replacement, Keyboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10 Phillips head 4.2 mm screws using PH#00 screwdriver from the key board chip.
  14. The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Sharper Image Literati Tablet Keyboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peal back the sensor array and keypad.
Spencer Dodder
crwdns2935283:003/21/18crwdne2935283:0
560 crwdns2915208:0crwdne2915208:0
IUPUI, Team S5-G4, Baechle Spring 2018 crwdns2935289:0IUPUI, Team S5-G4, Baechle Spring 2018crwdne2935289:0
IUPUI-BAECHLE-S18S5G4
crwdns2942667:0crwdne2942667:0 265
