The Sharper Image Literati Tablet's Keyboard may need to be replaced due to wear on the keys within a few years of purchase. The Keyboard replacement for The Sharper Image Tablet can be done in approximately half an hour to forty five minutes with moderate difficulty level in nineteen steps. Keyboard replacement for The Sharper Image Literati Tablet can help your device look new once more.
Wedge plastic spudger tool between the back panel and the body of device.
Pry apart the back panel and the device.
Desolder the battery wires from the circuit board.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
Unclip ZIF clip from the chip and unplug ribbon cable.
Detach the peripheral edge with plastic wedge.
Remove screws from the large metal shielding.
Remove the silver backing plate and the adhered SD port chip.
Remove the 10 Phillips head 4.2 mm screws using PH#00 screwdriver from the key board chip.
Peal back the sensor array and keypad.
This is NOT how you open them!!! I broke one of mine doing this. The white part SLIDES UP! DO not ply it open!!! Slide it up ( it needs a LITTLE ply around the silver part. ) It comes off then there are TWO SCREWS holding the brown part down. Once you remove the two screws ( they are under the white part ) then you can slide up the brown part too.
