The Pave Parisien Speaker: Battery replacement
  1. The Pave Parisien Speaker: Battery replacement, Remove the grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Remove the grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the protective grille by lifting one of the four corners.
  2. The Pave Parisien Speaker: Battery replacement, Opening the speaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Opening the speaker: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws using a m4 allen wrench
  3. The Pave Parisien Speaker: Battery replacement, Disconnecting the speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Disconnecting the speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the speaker out a bit to access the connectors
    • With light gentle movements, pull and disconnect the two cables from the connections
  4. The Pave Parisien Speaker: Battery replacement, Pulling the board out of the case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Pulling the board out of the case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the speaker completely out of the recessed compartment
    • Gently pull the board behind the speaker out and place on a flat surface
  5. The Pave Parisien Speaker: Battery replacement, Disconnecting the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Disconnecting the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Disconnecting the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery connector from the board
    • Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure
  6. The Pave Parisien Speaker: Battery replacement, Removing the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Removing the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the battery from the rear towards the opening where the wires are
    • The battery is out and now it can be changed
  7. The Pave Parisien Speaker: Battery replacement, Connecting the new battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Connecting the new battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Connecting the new battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pass the connector through the space that is indicated for it
  8. The Pave Parisien Speaker: Battery replacement, Reinstalling the board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The texture of this surface is different from the other three faces. Orient yourself to how it fits correctly.
  9. The Pave Parisien Speaker: Battery replacement, Reinstalling the speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Pave Parisien Speaker: Battery replacement, Reinstalling the speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation
  10. The Pave Parisien Speaker: Battery replacement, Finished: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally replace the speaker grill: your Pave Parisien is ready to use!
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Le Pavé Parisien
crwdns2935283:004/03/19crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 185
