The Claw Item Replacement
  1. The Claw Item Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Item Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Item Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Item Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Item Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover of The Claw machine.
  6. The Claw Item Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 The Claw Item Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Item Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Item Replacement, Overfill: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After emptying out contents have The Claw machine facing you
  9. The Claw Item Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • View the Claw machine from the top
  10. The Claw Item Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place thumb on grip section and pull away from the Claw machine.
  11. The Claw Item Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place items in the Claw machine.
Alain Pierre
crwdns2935283:003/22/16crwdne2935283:0
1.188 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-8, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 4-8, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S4G8
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 1,835
