crwdns2959928:0crwdne2959928:0 ↓If you are experiencing trouble with the claw or it does not seem to be opening or closing properly, it is possible that the claw itself is broken or damaged. This requires the user to open the claw device in order to access the mechanical claw. Follow this easy guide in order to properly and easily replace your claw.
Place The Claw machine in the up-right position with the control knobs facing you.
Turn The Claw machine upside-down placing the top cover on the surface of your work area.
Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
Turn The Claw machine back to the upright position with controls facing you.
Remove the top cover of The Claw machine.
Remove the ten 6 mm phillips #1 screws from the top flange.
Lift the flange upward and off to the side of the machine.
Locate the small rings that attach the chain to the plastic claw.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
crwdns2947412:07crwdne2947412:0
Where do I buy a new grabber thing
Oliver Chew - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The 1st joystick that moves the claw forward and back doesn’t work.
Michelle Bianchini - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What if the chain won't go down as it deep as it used to be?
Mira DIP - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
Greg Sturges - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My chain fell off and I dont know how to fix
Kathellyn Da silva - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
