Texas Instruments TI-84 Plus CE Battery Replacement
  1. Texas Instruments TI-84 Plus CE Battery Replacement, TI-84 Plus CE Battery Repair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure your TI-84 Plus CE is off before starting the repair.
    • Any objects in your RAM will be removed if the battery is taken out. To ensure your objects are safe, archive them or back them up to a computer.
  2. Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the 2 Philips screws on the back of your calculator, as outlined.
    • These screws are not to be confused with the 6 Torx T6 scews surrounding the calculator.
    • With a Philips 0 or 00 screwdriver, unscrew the two screws.
    • The two Philips screws will not come out of the battery door, and will stay attached. Do not attempt to remove them completely.
  3. Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery door by grasping one of the two screws that are unscrewed, and pulling upwards.
    • Be sure to lift gently, as little force is needed to get the battery door removed.
  4. Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the battery using your nails, by inserting your nail into the small cut out, and lifting up on the battery.
    • As an alternative, you can use an opening tool. Go to Step 5 to see the procedure.
  5. Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put your opening tool in the small opening as described in the photos.
    • Gently pull out the battery. You may need to hold your calculator to prevent your calculator from sliding around your working surface.
crwdns2935229:015crwdne2935229:0
o355
crwdns2935283:003/26/16crwdne2935283:0
561 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Where can I buy the replacement batteries?
louis liu - crwdns2934203:0crwdne2934203:0
Hey louis liu, I updated this guide with a link on where to buy the battery. It cost about $12 USD on Amazon: http://a.co/d/iTK2V0v
TheLastMillennial - crwdns2934203:0crwdne2934203:0
I replaced the battery and it worked for 1 week, the battery icon was on the screen which didn’t seem to get charged in full. After a week, the calc didn’t work anymore.
Lesly Simon - crwdns2934203:0crwdne2934203:0
So you're saying when you try charge the calculator it doesn't charge the battery at all? Does the LED next to the charging port turn solid orange when you plug it in? Have you tried a different power source (i.e. your computer or a wall block) or a different cable?
TheLastMillennial -
Thanks, I’ve updated the guide with that link.
TheLastMillennial -
This was no help whatsoever. My problem is that I cannot plug the new battery back in. I hesitate to use too much force because I don't know which is top up on the plug. Do the metal pieces you can see go face up or face down? Why doesn't the plug just slide right back in?
Karen Hector - crwdns2934203:0crwdne2934203:0
Does the battery you have look like the battery in this guide or does yours have a wire connected to it? The metal pads on the battery will go to the top right corner.
The metal prongs on the calculator's body are springy which is why the battery doesn't just fall into place. Do any of the prongs look different from the others (is one bent out of shape)? If not, you can just push the battery into place; you shouldn't have to force it in.
TheLastMillennial -
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 285
crwdns2942667:0crwdne2942667:0 53,188
