Texas Instruments TI-83 Plus Motherboard & Screen Replacement
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
    3. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
crwdns2935229:020crwdne2935229:0
Kevin
crwdns2935283:010/02/12crwdne2935283:0
479 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-37, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 18-37, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S18G37
crwdns2935297:018crwdne2935297:0
crwdns2947412:016crwdne2947412:0
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 107
crwdns2942667:0crwdne2942667:0 51,523
