Texas Instruments TI-30X IIS Battery Replacement
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
crwdns2935229:020crwdne2935229:0
Ryan
crwdns2935283:003/01/15crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 35,255
