Tennis Racquet Grip Tape Replacement
  1. Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the rubber collar towards the tennis racquet head off the handle.
  2. Tennis Racquet Grip Tape Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unwrap the tape on the tennis racquet handle top.
  3. Tennis Racquet Grip Tape Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tennis Racquet Grip Tape Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tennis Racquet Grip Tape Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old grip.
    • Some older tennis racquets may have a few staples holding the grip to the buttcap. Use the staple remover to take them out.
  4. Tennis Racquet Grip Tape Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
  5. Tennis Racquet Grip Tape Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tennis Racquet Grip Tape Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Face the racquet so the buttcap is towards you.
    • If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
    • If you are right-handed, wrap the tape towards the left
    • Wrap the grip flush with the buttcap base.
  6. Tennis Racquet Grip Tape Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tennis Racquet Grip Tape Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
    • Stop wrapping just before you finish wrapping the handle.
    • The handle is the off color or unpainted portion below the tennis racquet head.
  7. Tennis Racquet Grip Tape Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tennis Racquet Grip Tape Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wrap the handle top with the backing on.
    • Mark a horizontal line parallel to the buttcap around the grip.
  8. Tennis Racquet Grip Tape Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut along the marked line using either scissors or a knife.
    • Cutting with scissors is significantly easier, however if you do not have scissors that can cut the grip, a knife will work.
  9. Tennis Racquet Grip Tape Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the backing and finish wrapping the replacement grip.
  10. Tennis Racquet Grip Tape Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
  11. Tennis Racquet Grip Tape Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tennis Racquet Grip Tape Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Complete your fix by pulling the rubber collar back to its original location.
    • If you do not wish to add an overgrip, skip step 12.
  12. Tennis Racquet Grip Tape Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the collar up off the handle.
    • Repeat steps 4 - 11 to apply the overgrip.
    I wrote a bout this but you just hit the nail! Thanks for sharing … The Best Way to Regrip a Tennis Racquet
    Paul Mwanyasi - crwdns2934203:0crwdne2934203:0
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
Aisleen Santos
crwdns2935283:004/28/17crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
UC Davis, Team S3-G1, Coad Spring 2017 crwdns2935289:0UC Davis, Team S3-G1, Coad Spring 2017crwdne2935289:0
UCD-COAD-S17S3G1
Thank you I’ve found particularly useful the, then obvious when you think about it, comment that left handed setup is different to the right handed one!
Sam Curti - crwdns2934203:0crwdne2934203:0
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
JACKSON RYAN - crwdns2934203:0crwdne2934203:0
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
Tennis Unit - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 120
crwdns2942667:0crwdne2942667:0 19,294
