For this repair you will be removing your old grip and replacing it with a new Replacement Grip that you purchased from a sports store. This guide will also explain how to apply an Overgrip that you may have purchased for a variety of reasons: disliking the texture of the replacement grip, feeling you want a thicker grip, or simply wish to protect the more expensive Replacement Grip.
Pull the rubber collar towards the tennis racquet head off the handle.
Unwrap the tape on the tennis racquet handle top.
Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
If you are right-handed, wrap the tape towards the left
Wrap the grip flush with the buttcap base.
Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
Wrap the handle top with the backing on.
Mark a horizontal line parallel to the buttcap around the grip.
Cut along the marked line using either scissors or a knife.
Remove the backing and finish wrapping the replacement grip.
Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
Complete your fix by pulling the rubber collar back to its original location.
Pull the collar up off the handle.
Repeat steps 4 - 11 to apply the overgrip.
I wrote a bout this but you just hit the nail! Thanks for sharing … The Best Way to Regrip a Tennis Racquet
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
Thank you I’ve found particularly useful the, then obvious when you think about it, comment that left handed setup is different to the right handed one!
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
I use this tennis guide, it’s quite worthy.
