Tengda S5 Plus Rear Camera Replacement
  1. Tengda S5 Plus Rear Camera Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the phone screen-side down.
  2. Tengda S5 Plus Rear Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Rear Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Rear Camera Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Rear Camera Replacement, Rear Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Rear Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Rear Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Rear Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the phone facing screen down.
    • Using the plastic prying tool, gently disconnect the black connector cable.
    • The connector cable should easy snap out with little force.
  7. Tengda S5 Plus Rear Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic prying tool, pry the camera from the tape holding it in place.
    • Be careful not to rip the tape.
Jholmesford
crwdns2935283:004/21/15crwdne2935283:0
224 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-9, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 14-9, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S14G9
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 405
