Tengda S5 Plus Home Button Replacement
  1. Tengda S5 Plus Home Button Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the phone screen-side down.
  2. Tengda S5 Plus Home Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Home Button Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Home Button Replacement, Home Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Home Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, create a small gap between the front screen and the metal casing. Slide the plastic opening tool around the phone counterclockwise to make this gap around the entire phone.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Home Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay your device with the screen faced down.
    • Using tweezers, lift the two pieces of yellow tape holding the wire in place.
  7. Tengda S5 Plus Home Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers again, grasp the wire and free it from the crevice.
    • This will provide slack for you to work with the lower motherboard.
  8. Tengda S5 Plus Home Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the silver tape that holds the lower motherboard to the front panel of the phone.
  9. Tengda S5 Plus Home Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, or the Metal Spudger, disconnect the black cable connector.
    • The cable connector should easy snap out with little force.
  10. Tengda S5 Plus Home Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, slide the lower motherboard towards you.
    • The lower motherboard will still be attached to the front panel by a red and blue cable on the left side and a long silver wire on the right side, but you should now have visibility of the home button.
  11. Tengda S5 Plus Home Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tengda S5 Plus Home Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean away any dirt from the back side of the lower motherboard, underneath the charging port.
    • Using tweezers, grasp and remove the home button.
Kenny Levy
crwdns2935283:004/20/15crwdne2935283:0
122 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-9, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 14-9, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S14G9
crwdns2942667:0crwdne2942667:0 463
