Telecaster Guitar String(s) Replacement
  1. Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start with the low E string (the furthest on the right). Unwind the string by turning the tuning peg counter-clockwise.
    • Keep the string secure by placing one finger on the string's nut slot.
    • After unwinding the string, the segment coiled around the post will come loose. Pull the string out of the post.
  2. Telecaster Guitar String(s) Replacement, Remove Old Strings: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Remove Old Strings: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Remove Old Strings: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Uncoil the end of the string as much as possible.
    • Caution: Use caution in handling the ends of strings as they are extremely sharp.
    • Pull the end of the string through the bridge and out through the back of the guitar.
  3. Telecaster Guitar String(s) Replacement, Insert New Strings: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Insert New Strings: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Insert New Strings: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of the new string through the corresponding hole on the back of the guitar.
    • Turn the guitar over and pull the string all the way through.
  4. Telecaster Guitar String(s) Replacement, Clip Excess String: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Clip Excess String: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Clip Excess String: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There will be extraneous string length while replacing the 5th and 6th (furthest to the right) strings. Using a wire cutter, you may opt to trim the length of these strings.
    • Stretch out the replacement string and cut it about 3-4 peg lengths away from the peg of the string you're replacing. In this case, you are replacing the 5th string and will cut the string near the 2nd string peg.
  5. Telecaster Guitar String(s) Replacement, Insert String into Peg: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Insert String into Peg: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Insert String into Peg: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the end of the cut string into the middle hole of the corresponding peg.
    • Keep pushing the end of the string to the bottom and bend the string until the outside segment touches the bottom of the guitar head.
  6. Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pushing the end of the string to the bottom and the outside segment to the guitar head, turn the tuning peg clockwise.
    • When the string is tight enough, you may release it. Make sure the string fits securely within the nut slot.
    • Using a tuner of your choice, tighten the guitar string until it matches the correct pitch.
Jasper
crwdns2935283:004/11/21crwdne2935283:0
214 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team S1-G17, Harris Spring 2021 crwdns2935289:0CSU Los Angeles, Team S1-G17, Harris Spring 2021crwdne2935289:0
CSULA-HARRIS-S21S1G17
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 9,662
