Tektronix TBS1062 Oscilloscope Disassembly
  1. Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all eight plastic buttons.
    • Remove the five Torx T15 screws.
    • Remove the front panel by pulling it off
  2. Tektronix TBS1062 Oscilloscope Disassembly, Removing the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Removing the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power plug from the cover
    • Firmly grasp the ON/OFF switch and pull it straight out of the box.
    • Press the button into the ON/OFF button recess until it clicks into place.
    • Remove the two black plastic plugs from the bottom.
    • Remove the back cover.
  3. Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Even when disconnected, the power supply can retain a dangerously high voltage. Avoid contact with the rear of the board or other components. Use insulated electrician's gloves. Ensure that the capacitors are discharged before touching them.
    • Disconnect the J101 power supply connector from the motherboard.
    • Disconnect the earth connection.
    • Remove the 5x Torx T15 screws.
    • Remove the power supply board.
  4. Tektronix TBS1062 Oscilloscope Disassembly, Control panel removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Control panel removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black cable from the motherboard
    • Pull the control board plate
  5. Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the three nuts holding the signal connectors.
    • Loosen the three T15 Torx screws.
    • Remove the cables.
    • Remove the main board.
  6. Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cable and the LCD backlight cable from the motherboard.
    • Loosen the 4x 8mm nuts from the display supports.
    • Remove the LCD display.
crwdns2934873:0crwdne2934873:0
pt en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Jose Gustavo Abreu Murta
crwdns2935283:007/06/10crwdne2935283:0
4.886 crwdns2915208:0crwdne2915208:0
This guide is written in English, not Portugese. How can that be changed?
Christopher Sean Harris - crwdns2934203:0crwdne2934203:0
Hi Christofer.
Do you intend to translate into Portuguese? I messed up the language when editing it.
Jose Gustavo Abreu Murta - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 776
