Teenage Engineering OP-1 Connector Board Replacement
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-1 Connector Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
crwdns2935229:047crwdne2935229:0
teenage engineering
crwdns2935283:010/23/13crwdne2935283:0
1,113 crwdns2915208:0crwdne2915208:0
crwdns2947412:044crwdne2947412:0
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - crwdns2934203:0crwdne2934203:0
Got the back panel off finally but my connector board won't come out.
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 361
crwdns2942667:0crwdne2942667:0 51,427
