Teddy Ruxpin Mouth Replacement
  1. Teddy Ruxpin Mouth Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Mouth Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Mouth Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Mouth Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Mouth Replacement, Arms: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Mouth Replacement, Arms: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Mouth Replacement, Arms: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Mouth Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Mouth Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Mouth Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Mouth Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Mouth Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Mouth Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Mouth Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Mouth Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Mouth Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Mouth Replacement, Housing Cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Mouth Replacement, Housing Cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Mouth Replacement, Housing Cover: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Mouth Replacement, Eyes: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Mouth Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Mouth Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Mouth Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
  14. Teddy Ruxpin Mouth Replacement, Mouth: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Mouth Replacement, Mouth: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove five 12.5mm Phillips #1 screws.
    • Pull the mouth mechanism out of the shell.
  15. Teddy Ruxpin Mouth Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Mouth Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
    • Open the mouth mechanism
Jayin Patel
crwdns2935283:001/23/20crwdne2935283:0
406 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G5, White Winter 2020 crwdns2935289:0Cal Poly, Team S18-G5, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S18G5
His mouth and nose fell out leaving a hole in his face. How do i fix it or is the repair shop local? He is 30 years old.
rrhall559 - crwdns2934203:0crwdne2934203:0
World of wonder made it and they aren’t in business anymore
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,805
