Teddy Ruxpin Arm Button Replacement
crwdns2869540:0crwdne2869540:0: 1.6 k
0
9
67
1,640
crwdns2955950:0crwdne2955950:0: 6
crwdns2960004:02crwdne2960004:0, crwdns2960008:04crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:020crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Is your Teddy Ruxpin story-time mood or singing not working? Your Teddy Ruxpin’s arm buttons might need to be replaced! This guide will take you through the proper steps on how to remove the buttons with ease. For this guide, all you will need is a pair of scissors and a Phillips #1 and #2 screwdriver. There are not many difficult steps but pull the wires with caution as you do not want to break them.
    1. Teddy Ruxpin Arm Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Arm Button Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the vest covering the back of the bear.
      • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
      • Captured screws will stay in place, no need to worry about losing this one!
    2. Teddy Ruxpin Arm Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the tab outward to remove the protective plate for the batteries.
    3. Teddy Ruxpin Arm Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
    1. Teddy Ruxpin Arm Button Replacement, Arms: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Arm Button Replacement, Arms: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Arm Button Replacement, Arms: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Cut the orange shirt and zip tie.
      • Remove the zip tie.
    2. Teddy Ruxpin Arm Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Cut across the back seam of the head of the bear along the arrow.
      • This damages the bear's exterior and will require resewing.
    3. Teddy Ruxpin Arm Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Arm Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teddy Ruxpin Arm Button Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the interior of the doll.
      • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
      • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
    4. Teddy Ruxpin Arm Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Arm Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Extract each arm button.
      • Pull on the stuffing of the bear and not the wire to remove the arm button.
    5. Teddy Ruxpin Arm Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teddy Ruxpin Arm Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull off the rest of the outside layer of the bear.
    6. Teddy Ruxpin Arm Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the arms from the main body.
Lauren
crwdns2935283:001/23/20crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G5, White Winter 2020 crwdns2935289:0Cal Poly, Team S18-G5, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S18G5
crwdns2935297:084crwdne2935297:0
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So has anyone figured out how to replace the button?
knrobinson83 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The plastic part of the button is what broke in my daughter's Teddy Ruxpin. She had a similar toy with a button in its hand that she no longer played with, so I took the plastic button part out of the old toy and fit it onto Teddy Ruxpin. I used the same wires and threaded them through the plastic button, then resoldered the wires to the small board in the button. Works perfectly now.
Eliza Zollicoffer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 67
crwdns2959996:0crwdne2959996:0 1,640
