A toaster's fuse will often fail over time. This guide will show you how to fix your Technostar Sandwich Toaster.
            Open the toaster.
            Remove the four screws which attach the mold.
            Remove the mold to get access to the heating coil.
            Cut the two wires that connect to the thermal fuse.
            Align the thermal fuse with the open wires.
            Put the spade connectors over the wires.
            Using pliers, clamp the wires together.
            Replace the molds.
            Replace the four screws which attach the mold.
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
how do i test that the reason that my toaster is not working is actually the thermal fuse?
