After making sure the weapon is clear -no bullet in the chamber- , release the striker by pulling the trigger. This releases the tension on the striker and allows the slide to come forward.
Pull the slide back just a hair to release the tension on the disassembly latches. Pull downward on the disassembly latches on both sides while holding rearward pressure on the slide, then release the pressure on the slide.
Continue moving the slide forwards until the rear of the slide passes the guides the notches above the disassembly latches(pointed out in the last picture).
The recoil spring assembly is on the bottom of the barrel. It is held in place by the spring's own tension against a notch in the barrel (2nd picture) and its slot in the end of the slide.
While holding the slide with the muzzle pointing away from you, put your thumb or index finger on the rear-facing portion of the recoil spring assembly. Push the assembly forward to free it from the tension against the barrel, then release the tension and pull it out of its slot in the slide.
With the recoil spring assembly no longer holding the barrel in, the barrel can now be removed.
Move the barrel slightly towards the bottom of the slide
Push the barrel forward a little bit to allow enough space to clear the ejector (not pictured)
You're finished! You have now successfully field stripped a Taurus G2C.
I put mine back together wrong..help
How far in the process did you get and what’s going on with it?
My recoil sping fell as I was in this stage of assembly now my barrel is stuck in trigger well. Not able to move
The barrel is stuck in the trigger well? I think I understand what you’re talking about. Firstly, make sure there is not a round in the chamber. After that, try pulling the trigger to see if that frees it up. If not, you may need to contact Taurus to see about either sending it in or having them verbally walk you through fixing it.
Another option for you is visiting a local gun shop and asking them if they know any gunsmiths in your area.
Hopefully it’s a quick fix.
To reassemble your weapon, follow these instructions in reverse order.
crwdns2935229:016crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Hello Josh. This is Matthew. Thanks for the field stripping instructions. Just wanted to let you know people are using your instructions. Safe shooting and have a good day
Hey Matthew! Glad to hear people are able to use my guide! Thanks for reaching out!!
Just wanted you to know I just used your information on taking apart my pistol. Great info.
Awesome, glad to hear it helped! Safe shooting and pass the knowledge along!
Thanks for the great tutorial. Very clear and concise.
