Tatung TAC-6G Power Cord Replacement
  1. Tatung TAC-6G Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the lid and bowl from the top of the device.
    • Be sure device is not plugged in before beginning replacement of power cord.
  2. Tatung TAC-6G Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn device upside-down so that the three legs point upwards.
  3. Tatung TAC-6G Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the one 7mm Phillips Head #3 spanner screw from the side of the brass panel.
  4. Tatung TAC-6G Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the brass plate from the device and set it aside.
  5. Tatung TAC-6G Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7mm Phillips #3 brass screw that connects the white power cord wire and blue wire closest to the power cord.
  6. Tatung TAC-6G Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10mm Phillips #3 brass screw above the heating element that connects the white power cord wire and the maroon wire.
  7. Tatung TAC-6G Power Cord Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, from the inside of the device, push the black plastic wire holder to release cords.
  8. Tatung TAC-6G Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the power cord through the hole, isolating the power cord from the device.
  9. Tatung TAC-6G Power Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the new power cord wires into the hole.
    • To ensure the power cord is compatible with the device, make sure that the replacement cord you are using has a proper insulating coating and uses a NEMA 1 plug. NEMA 1 plugs are the common type of plug that have two parallel "|" shaped metal beams.
Katy Weber
crwdns2935283:001/28/16crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-6, Sydow campbell Spring 2016 crwdns2935289:0University of Alabama, Team 1-6, Sydow campbell Spring 2016crwdne2935289:0
UA-SYDOW CAMPBELL-S16S1G6
Thanks! Ours wore out at the crimped part where the cable exits the rice cooker. After opening it up, we cut the cable ~6" from the loose end (not the plug end!), separated the two wire bundles, stripped part of the black plastic off (~1/5") slid the fiberglass sheaths over to the new bundles and attached w/o the circle metal ends by screwing it into the original place.
carole - crwdns2934203:0crwdne2934203:0
Where do you get this particular replacement power cord?
Riceman - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 3,138
