Taranis X9D & X9D Plus Hall Effect Gimbals Replacement
  1. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement, Hall Effect Gimbals: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the device so that the bottom is facing up.
    • Slide the battery compartment open.
    • Pull the battery by the plastic connector (not the wires) and shim left and right until the cable disconnects.
  2. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight screws holding the gimbals to the front of the case using a 2.5 mm Hex key.
    • Push all switches forward or away from you (this will be important for reassembly).
  3. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove six screws from the back of the device using a Phillips #0 screwdriver.
    • Ensure the switches are in the position from the previous step, as they are not held in place and can reverse direction.
    • Gently pull the back up and open the radio in the form of a book, with the battery compartment being the spine.
    • Lay the controller on its front so that as the last screw is removed, the two halves don't fall apart.
  4. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach a total of six connectors (three per gimbal).
    • Pull the gimbals out from the radio frame.
  5. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • New gimbals come in left and right boxes, respectively, so as not to mix them up, as well as identical connections for a drop-in replacement.
    • New gimbals will include new hex bolts for the front, as the stock ones will not fit.
    • When dropping the new gimbals into place, the harnesses will face downwards on their respective side.
    • Do not press on the cables. Push down on the connectors with your thumbs.
  6. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reattach the eight screws back onto the frame of the controller using a 2.5 mm Hex key.
  7. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the radio back up like a book, and verify the switches are in the same position.
    • Reattach the six screws to the back panel using a Phillips #0 screwdriver.
  8. Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Taranis X9D & X9D Plus Hall Effect Gimbals Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the battery and the battery door.
    • Turn on the radio and verify the correct installation from the on-screen information (check the switch positions with the on-screen display).
    • New gimbals may require recalibration depending on the settings of your stock gimbals.
Saad Irfan
crwdns2935283:010/20/23crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 13-2, Ribeiro Fall 2023 crwdns2935289:0CSU Los Angeles, Team 13-2, Ribeiro Fall 2023crwdne2935289:0
CSULA-RIBEIRO-F23S13G2
crwdns2942667:0crwdne2942667:0 325
