Tapwave T2907US Zodiac 2 Shoulder Button Replacement
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four Torx T5 screws from the back panel.
    2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wedge a spudger in between the front and back panel.
      • Apply leverage downwards to the spudger in order to remove the back panel.
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the battery out from under the brown wire-tape.
      • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
    2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 2 Philips #00 screws on each end of the motherboard.
    2. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull off the black memory card slot piece with tweezers.
    3. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 2 Philips #00 screws on each side of the charging port.
    4. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
    5. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
      • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
    6. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
    7. Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tapwave T2907US Zodiac 2 Shoulder Button Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the large brown wire-tape from the motherboard.
      • Peel the black tape back from the wire-tape using tweezers.
      • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
      • The screen and motherboard components can now be separated from each other.
    1. Tapwave T2907US Zodiac 2 Shoulder Button Replacement, Shoulder Button: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Desoldering Pump
      $3.99
      • Carefully remove the solder between the shoulder buttons and the motherboard with the soldering sucker.
      • Try to avoid contact between the solder sucker and other components surrounding the shoulder buttons.
      • For more information on desoldering, look at this soldering/desoldering guide.
Daniel Wiseman
crwdns2935283:001/20/12crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-33, Amido Winter 2012 crwdns2935289:0Cal Poly, Team 10-33, Amido Winter 2012crwdne2935289:0
CPSU-AMIDO-W12S10G33
crwdns2935297:096crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 1,373
