This guide will help you replace your taillight bulb on a Volkswagen Jetta (2011 - 2018). The most common problem on a vehicle is a burn-out taillight which can cause a safety hazard for other drivers on the road. Not only is this a safety hazard to other drivers but, you could also receive a fine from the Police.
By following this guide you will be able to replace your taillight bulb effortlessly without any special equipment/tools. This guide lists all the steps and includes detailed information and pictures of the process. It should take approximately 45 minutes to complete this repair but, it may take a little longer depending on your experience.
Open the trunk of your vehicle.
Start unscrewing the large plastic screw counter-clockwise.
Remove the taillight assembly by gently wiggling it out with both hands.
Unplug the taillight power plug by pinching both tabs to release the plug.
Pinch the two release tabs towards each other and lift the bulb bracket out of the tail housing.
Gently turn the bulb counter-clockwise until you can pull it out.
