This guide will show how to replace the volume button on your Tagital T9X tablet.
With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
Remove the broken volume button from the plastic case. Replace it with the new volume button, with the + being closer to the camera opening.
